Engine, loom, ecu, turbo, exhaust as far as cat, ignitor, coilpacks, clutch, flywheel be most of it anyway. Gearboxes are all the same
5th gear has a shorter ratio in an n/a
wasnt aware of any clutch or flywheel difference either other than a slight size difference if your sr20de clutch is good you can still run it but if you want to change to a det clutch you need the flywheel too
