Results 1 to 3 of 3
Thread: sr20det swap
    di Member leemc180's Avatar
    May 2014
    Default sr20det swap
    Does anybody know what different parts are needed for swapping an sr20det from an s14 n/a the xars n/a at the moment but just wondering is the gearbox or loom different? Thanks
    Engine, loom, ecu, turbo, exhaust as far as cat, ignitor, coilpacks, clutch, flywheel be most of it anyway. Gearboxes are all the same
    di Member conor's Avatar
    Castlebar co.Mayo
    Quote Originally Posted by Stevo View Post
    5th gear has a shorter ratio in an n/a
    wasnt aware of any clutch or flywheel difference either other than a slight size difference if your sr20de clutch is good you can still run it but if you want to change to a det clutch you need the flywheel too
