Results 1 to 10 of 17
Thread: Abs in nct
    di Member Driftma's Avatar
    Dungarvan,Co.Waterford
    If the car has abs aka you open the bonnet and you see a abs pump the light has to work as it should.
    Jan 2011
    Cavan
    Quote Originally Posted by Driftma View Post
    If ya remove the pump, the light the sensors, whats the story then?
    Once there's no pump , light or sensors it should pass 100%
    Senior Member grange's Avatar
    small bit or wire and wire the bulb to the oil light/etc on the cluster it will turn off when the oil light turns off
    team ball bag
    Jan 2011
    Cavan
    Quote Originally Posted by pepsterx View Post
    take it out if it's not there how can they fail you on it not working! I think it's mandatory on on vehicles post mid 2000's.
    Found it, anyone know what year?
    Also whats the story if the light is working properly but theres no pump.
    di Member Foxyfenlon's Avatar
    Dec 2011
    Wexford
    Could he not just pull out the fuse for the abs when he wants it off and put it back in for normal driving, i've read about lads doing that with silvia's and it works no problem, could be different on an is200... Worth a try though,
    You could even put it on a switch...
    May 2012
    south tipperary
    depends on how cute the testers are.. i know few testers and the smart ones know when u turn on the ignition the ABS does a check and after usually 5secs the abs light goes off even with the engine off, so they can check if its wired off the oil pressure switch or anything else.. there not really failing on it much but be aware they could.. they failed me on the laurel last test for having the pump and sensors and no ABS light, wankers, twas easily sorted but still hassle.. its a fuckin money racket..
