Results 1 to 10 of 17
Thread: Abs in nct
    Jan 2011
    Cavan
    Default Abs in nct
    Well lads seen this on here before but i cant find it now, does anyone know from what year is it mandatory to have abs on a car from? Cheers for any help.
    di Member Driftma's Avatar
    Dungarvan,Co.Waterford
    If the car has abs the light on the dash has to work properly
    Jan 2011
    Cavan
    How do lads get away with abs delete kits in s bodys? Im certain theres a year limit, 2000 or 2001, summit like that, just cant remember which.
    Ive a 94 and a 95 silvia there, neither are ABS
    Jan 2011
    Cavan
    Quote Originally Posted by Stevo View Post
    My 180 is 96 and it had no abs either, thats not what i need to know though, cheers.
    Junior Member BluhBluh's Avatar
    Jun 2013
    Waterford City
    Do they even check if the ABS works or if there is ABS at all? On my e36 there is ABS but it dosent work. The ABS light used to be always on and i just wired the abs light bulb to a different bulb so it would turn on and off when starting the car. Never any problems with that in NCT.
    Quote Originally Posted by Boguey001 View Post
    Abs light in your cluster??
    Jan 2011
    Cavan
    Not sure, its not for me im asking, one of the lads has a 01 is200 and he wants to do an abs delete on it, thats why im asking.
    If the car has abs aka you open the bonnet and you see a abs pump the light has to work as it should.
    Jan 2011
    Cavan
    Quote Originally Posted by Driftma View Post
    If ya remove the pump, the light the sensors, whats the story then?
