Results 1 to 9 of 9
    i went from master cylinder>hydro> rear line on abs pump and removed abs and asc relays.
    didnt fancy cutting and flaring the 2 pipes as they are hard to do. only awkward bit was trying to get the right connector for the master cylinder, was an m12 with a fine pitch. got them in ashgrove inter parts in dun laoghaire eventually.
    will pass the test as long as you keep the mechanical handbrake.
    Thanks for the input, looks like il be albe to sort something out so.
    400 horses............. 1 jockey
    di Member conor's Avatar
    Castlebar co.Mayo
    if you are going t pieceing it you will need a hydraulic brake line flaring tool by right
    Quote Originally Posted by kev.skyline View Post
    This is the only way to do it correctly and still maintain the correct feel.
    Also the same way i had my own done.
    Chap in the place my workshop is in breaks lots of bmws so if you need any fittings send me a pm and ill take them out of a car.
