A mate has a 98 320 e36 and wants a hydro fitted but was told it can't be done because it has ABS and they have individual lines going back to the calipers
Is there a way of T'ing into this setup or what?
Just get a t-piece but if it was for the road it might not pass the test with it like that
It is for the road mate yeah
the two break lines are on account of traction control not abs,
if i were you i would tee from two into 1 to put my hydro in,
remove the abs fuses, and you can put them back in for test etc
remove asc fuses alltogether tho
i went from master cylinder>hydro> rear line on abs pump and removed abs and asc relays.
didnt fancy cutting and flaring the 2 pipes as they are hard to do. only awkward bit was trying to get the right connector for the master cylinder, was an m12 with a fine pitch. got them in ashgrove inter parts in dun laoghaire eventually.
will pass the test as long as you keep the mechanical handbrake.
Thanks for the input, looks like il be albe to sort something out so.
