hopefully il get a chance to do the clutch on my 180 tomoro is there any tricky bits doing it or are they handy enough? if i dont get a chance in work tomoro its gonna be a saturday job on axle stands so hoping there not too bad ha
if u aint first...your last. SHAKE N BAKE!
Only shitty ones are the very top ones under heater pipes, i use a stubby spanner there once cracked,
Top left from underneath is a little awkward, good long extension and a wobble attachment.
Theyre v v straight forward.
You Only Live Once
if you drop the box mounts it makes them top ones alot easier
cheers lads, just hope its the release bearing making all the noise now and not the box ha.
Absolute bastard the top ones are when its up in the air jack the front of the engine up to push the back of it down you will probably need 2 or 3 feet of extension bars and a wobble socket
20min on the deck Anto handy box, dont mind the bullshit, gun the bellhousing bolts out, just add couple of extensions and you are away !!!!!
