Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Member
    Feb 2012
    dublin
    Default removing sr20det gearbox
    hopefully il get a chance to do the clutch on my 180 tomoro is there any tricky bits doing it or are they handy enough? if i dont get a chance in work tomoro its gonna be a saturday job on axle stands so hoping there not too bad ha
    if u aint first...your last. SHAKE N BAKE!
    di Member pinny's Avatar
    Mar 2011
    Galway
    Only shitty ones are the very top ones under heater pipes, i use a stubby spanner there once cracked,
    Top left from underneath is a little awkward, good long extension and a wobble attachment.
    Theyre v v straight forward.
    You Only Live Once
    if you drop the box mounts it makes them top ones alot easier
    Member
    Feb 2012
    dublin
    cheers lads, just hope its the release bearing making all the noise now and not the box ha.
    di Member derek89's Avatar
    Nov 2011
    Dublin
    Quote Originally Posted by antokwon View Post
    Ye that's wat I thought but was the box hA
    also found it very handy to release the engine mounts and jack the front of the engine up the box slides right off and back on no hassle.
    Nov 2011
    Absolute bastard the top ones are when its up in the air jack the front of the engine up to push the back of it down you will probably need 2 or 3 feet of extension bars and a wobble socket
    di Member pepsterx's Avatar
    Mayo
    20min on the deck Anto handy box, dont mind the bullshit, gun the bellhousing bolts out, just add couple of extensions and you are away !!!!!
    Nov 2011
    Quote Originally Posted by pepsterx View Post
    I'd say your a real Gunther with a spanner in your hand
    Jul 2011
    Kildare
    I agree Lad took the gearbox out in just over half an hour. Put the engine and box back in a few hours. Easy car to work on.
    Mayo
    Quote Originally Posted by James Doyle View Post
    I sure am, the roughest you'll ever meet !!!
    If you think SR box is tough going i'd say give up mechanics now, if you are one any way !!!
