did u check fuel pressure lad,
also check for boost leaks
could be coils failing is it like a misfire?
if u aint first...your last. SHAKE N BAKE!
coils,boost leak,fuel pump,afm,loose connections on ecu???
it could be 1 of soooooo many things man i had same problem with my driftcar and only found the problem latley....has it got a walbro pump or uprated injectors??
check the plug tips.that will tell you whether its running rich or lean.
If you want dude we can go out to my garage some night or this weekend and we sort it. Can take stuff off mine till we find the problem
