Results 1 to 10 of 13
Thread: 180sx problem.?
    Member
    Feb 2012
    dublin
    could be coils failing is it like a misfire?
    if u aint first...your last. SHAKE N BAKE!
    coils,boost leak,fuel pump,afm,loose connections on ecu???
    cork
    Quote Originally Posted by mattybyrne2008 View Post
    could be all the above! did it all myself so god knows what ive done! how would i troubleshoot each?
    cork
    Quote Originally Posted by antokwon View Post
    ya a serious misfire!
    it could be 1 of soooooo many things man i had same problem with my driftcar and only found the problem latley....has it got a walbro pump or uprated injectors??
    cork
    Quote Originally Posted by joey banana s14 View Post
    ya has a walbro alrite bud. totally forgot bout the avcr stuff too. ill sort that out this week if i can. up the walls at the moment.
    cork
    check the plug tips.that will tell you whether its running rich or lean.
    Cork city
    If you want dude we can go out to my garage some night or this weekend and we sort it. Can take stuff off mine till we find the problem
    Quote Originally Posted by topdog View Post
    exactly what ya need to do and remove intercooler pipes and sometimes best off replacing joiners and clamps
    cork
    cheers bud appreciate it. i,ve nct saturday of all things and suppose to be away saturday night. if u pm you're number there ill give ya a text in the next few days and see if i could sort out some evening,
