Results 1 to 10 of 10
    Default 1jz non vvt M/T ecu
    Bit of a long shot but has anyone got a manual ecu for a jzx90??
    For some reason my car has an A/T ecu even though the car is manual.
    Cheers
    di Member 1jsoarer's Avatar
    Why do you need a m/t one? afaik there bought the same, except you have to cut a wire or two that isolates the automatic start position. Ive an auto ecu with my fcon and it seems to be fine!!
    Signature removed
    JZ For Life! Greg's Avatar
    I've an auto one in my car and have had no hassle with it, in fact it's on it's second auto ecu.
    Prominent Member mickel's Avatar
    Leitrim
    what happened the first one greg?
    di Member conor's Avatar
    Castlebar co.Mayo
    the capacitors shit themselves and damage the board of the ecu very common problem on 1jz ecus
    Darren that's what I was worried about??
    Is there much involved to get it to work proper with an fcon??
    Cheers for the reply people
    Quote Originally Posted by mickel View Post
    Nothing. I sold it to Carpo when I git a Power FC, then took a different auto one in part ex when I sold the Power FC.
    No mark, i just pluged mine in and she fired up straight away, yours should do the same because it has already be runnin your manual, its only one wire for a netural start switch so they dont start in drive! did you check with robbie if he can map the single on the fcon-is cause i heard something about not havein enough of a grid to map the big tubby!
    Signature removed
    hey buddy, an auto ecu can run on a manual box, but a manual ecu can't run an auto. your car was originally an auto before, i knew some of the previous owners in fact all the rear seat belts in your car came from my car back in 07 when i built mine for track.
    Quote Originally Posted by MarkII View Post
    Yeah the dude I bought it off was tellin me that when I got it off him!
    Cheers lads, its strange because on the chassis plate it says r154 which would mean it must of been manual out of the factory??
