Bit of a long shot but has anyone got a manual ecu for a jzx90??
For some reason my car has an A/T ecu even though the car is manual.
Cheers
Cheers
Why do you need a m/t one? afaik there bought the same, except you have to cut a wire or two that isolates the automatic start position. Ive an auto ecu with my fcon and it seems to be fine!!
Signature removed
I've an auto one in my car and have had no hassle with it, in fact it's on it's second auto ecu.
My JZX100 from grandad mobile to drift toy thread.
--->>>>http://www.driftireland.com/forum/showthread.php?t=121
the capacitors shit themselves and damage the board of the ecu very common problem on 1jz ecus
Darren that's what I was worried about??
Is there much involved to get it to work proper with an fcon??
Cheers for the reply people![]()
No mark, i just pluged mine in and she fired up straight away, yours should do the same because it has already be runnin your manual, its only one wire for a netural start switch so they dont start in drive! did you check with robbie if he can map the single on the fcon-is cause i heard something about not havein enough of a grid to map the big tubby!
Signature removed
hey buddy, an auto ecu can run on a manual box, but a manual ecu can't run an auto. your car was originally an auto before, i knew some of the previous owners in fact all the rear seat belts in your car came from my car back in 07 when i built mine for track.
