Results 1 to 10 of 22
Thread: Oil temps
    Site Trader: TDP - Trackday Performance
    Quote Originally Posted by ste View Post
    Noticed at practise day in mondello that my oil temps went over 120 degrees am I right in thinking that's defo too high??
    Will an oil cooler make a big difference to the temps??
    I'm not using big branded gauges but the water temp and boost are accurate enough compared to my avcr and old greddy water temp gauge that broke so it has me thinking the oil temp gauge is accurate too..
    Wat oil temps have u guys noticed in your own cars??
    Cheers
    Ste 120 deg C is not to high at all. If your using 15w50 Mobil or Silkolene then the oil should be in the range of min 100 deg C and max 150 deg C and up to 170 deg C for short periods of time.
    If you fit an oil cooler and the temp is to low there are problems also.
    Quote Originally Posted by mr.jailbait View Post
    temp gauges are normally spot-on,whether theyre a decent brand or not
    unlike pressure senders
    i cant remember the exact numbers,but ive seen before how oil that has reached a certain temp loses its viscosity and cannot protect an engine anymore
    your figures are fairly high.iirc even 100 degrees is too much
    im sure if you google it it'd bring up some info
    I think your wrong here as the oil will only reach the correct viscosity for max protection at 90-110 degrees.
    ye ill have to invest in one so.... cheers for all ur help
    If you get one STE make sure its a thermostatically controlled one.
    Robbie
    cork
    Quote Originally Posted by robbie@tdp.ie View Post
    i thought that any oil that repeatedly heated over 104 deg celsius loses its abililty to cool and lubricate
    and the hotter it gets,oil pressure reduces
    dont know about fancy oils
    Senior Member ste's Avatar
    north dublin
    Ok Robbie cheers for the advice much appreciated as always, in your opinion do u think it is wise using an oil cooler bearing in mind what u said if temps remain too low??
    Was gonna put up a thread later about oil coolers and are they worth it.. ill watch here instead lol
    Until you break the 400-450 bhp mark Id say they are not needed in Ireland.
    It depends on how you drive of course.
    Robbie
    north dublin
    That's all I needed to hear Robbie, thanks so much:-)
    Robbie
    320ish bhp and not ragged to death on track, no real need for a oil cooler then robbie?
    No need IMO.
    Robbie
    No need IMO.
    Robbie
    Cheers robbie! One less thing to fit/worry about
    in my old jzx 81 my oil temp would go up to 150 very quickly and the water temps very high too after two or three fast laps around mondello, and if i haden had guages would not have known, and that was a basically a standard 1j with standard rad and no oil cooler, but from what i have heard 1j's and rb's heat up alot quicker than sr's
    is the thermostatic plate essential, i got a nice blitz cooler kit and it doesen have one was planning on blanking over the cooler when not needed, but guess its giving the oil pump alot more work to do?
