Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Oil temps
    Senior Member ste's Avatar
    north dublin
    Default Oil temps
    Noticed at practise day in mondello that my oil temps went over 120 degrees am I right in thinking that's defo too high??
    Will an oil cooler make a big difference to the temps??
    I'm not using big branded gauges but the water temp and boost are accurate enough compared to my avcr and old greddy water temp gauge that broke so it has me thinking the oil temp gauge is accurate too..
    Wat oil temps have u guys noticed in your own cars??
    Cheers
    cork
    temp gauges are normally spot-on,whether theyre a decent brand or not
    unlike pressure senders
    i cant remember the exact numbers,but ive seen before how oil that has reached a certain temp loses its viscosity and cannot protect an engine anymore
    your figures are fairly high.iirc even 100 degrees is too much
    im sure if you google it it'd bring up some info
    MEATH
    Thermostatic oil cooler and a larger sump pan would be a good investment ste
    di Member shaneS14's Avatar
    think itll be about 80-100 with an oil cooler on track
    Wicklow/Dublin
    90-110 with the oil cooler, depending on the outside temp in my s13
    north dublin
    Does different grades of oil withstand higher temps ??
    Mar 2011
    carlow
    yeah different weights and different grades have a lot in the difference of oil temps
    but 120 degrees is fairly normal when going around mondello however a thermostatic oil cooler will help
    as i"ve only ever used 15/50 mobile one oil and have a thermostatic oil cooler and have often had the oil at 125 degrees but would need a few cool down laps when around this temp......
    WEZ is the man for 140 degrees temps.......
    north dublin
    Quote Originally Posted by ken red 180 View Post
    cheers for the help ken
    it all depends what oil your using ste.. Mine does be up around the 110 mark and when i really drive her on hard it will go 115.. i was running mobil 15w50 but nowhave chance to valvoline racing oil..
    di Member juice's Avatar
    Hiroshima, Japan
    You should buy my oil cooler
