the number of teeth on the cw and pinion are usually stamped on the side of the cw, if you take the back plate off find the numbers and divide them into one another....saves trying to count them yourself...this means taking the plate off and resealing afterwards....but easiest way is to mark the output shaft and count how many times the input turns for one rev of the output as said above
