If it's on the floor take off the back plate and find the numbers on the cw. As said divide the small into the big number to get the ratio
It'll be the most accurate way I'd reckon
the cwp will be oem part, aftermarket 2way diffs are generally just the center of the diff
thanks to chrisb,2tonne and calicagesracer for help done the marking trick first looked lik 4.3 so whipped casing off 48:11 = 4.36 cheers lads at least i know the crack now fairplay appreciate it!![]()
I know ur sorted but for anyone else that need to know what to look for..Look for the stamped numbers on the crown wheel
