Results 11 to 20 of 25
  1. #11
    Croom/Adare Co Limerick
    done a bit of research and it turns out it is the giggling pin thats loose doug.....check it out incase it falls out
    Originally Posted by carlow-drifter
    id say i have much more mechanical knowledge then some on here , grew up watchin me dad working on bus engines , so id say i have about 25 years experience , dunno why i even asked ye clowns
    Originally Posted by Derk
    I dont think you have as much knowledge as you think you have...
    I grew up watchin Bosco, that doesnt mean i live in a box with a hand up me arse now
  2. #12
    di Member doug's Avatar
    Feb 2011
    clare
    yea do this, start pulling fuse by fuse until theres no current draw, then you no what circuit its on, common one are electric aeriel! just make sure if uve connected the multi meter in series u dont open the door an interior light comes on an uve blown the fuse in the multi meter haha
    what way do i do this? just stick it on the battery and see when it changes as i pull fuses? or what way do i? sorry never did it before
  3. #13
    Senior Member paulr5's Avatar
    Oct 2010
    Takeshi's Castle
    Cliffords with the blackjack system do drain the battery, the system is constantly looking for tilt, motion, proximity or noise activity.
    It would be a win/win if you fitted a kill switch.
    Originally Posted by sc86
    better thread would be pics of all the savage jap cars parked up hidden around the country in sheds!
    No because whores like you will buy em and break em
  4. #14
    its not low enough!
    Quote Originally Posted by doug View Post
    dis connect the live off the battery connect the multimeter in series with the battery power lead, so one prong to the + terminal an one to the + lead, when set on ampmeter, itll tell u what sort of draw u have on the battery! anything over 10ma is abit high! remember to disconnct your door open switch before doing this by the way,
    now go to your fuse box an pull fuse 1, go look at current draw, go back insert fuse 1 pull fuse 2 look at draw etc, keep going untill youve found the fuse where when its out the current draw is very little, the its on this circuit u have a constant draw,
    i bet u itll b on the radio fuse circuit !
  5. #15
    cudnt be great idea puttin in kill switch, really good alarm thats isolated wudnt make sense car be robbed from outside ur house pointless having the alarm. cud a alarm drain a batt this fast? strange 1
  6. #16
    Feb 2011
    clare
    the alarm does have alot of fancy crap on it, i was thinking of gettin it looked at refitted or something but im in the clare limerick area and they only ones doin clifford are up around dublin!
    i like the sound of the kill switch but as said the alarm wont be working then. so with the muppets about the place some fucker might get into the car without me knowing..
    i will try checking the current as you said and see. thanks lads. the car is coming off the road i want to strip it and build it back up again with everything perfect.
    thanks for the help il post when i solve the problem!
  7. #17
    well man i had prob with my jeep few weeks ago batt kept goin dead turned out the clamp that goes on plus or minus there was two terminal screws that lock the cable tight to the clamp, they were loose & there wasnt enough jizz gettin in, i near bought new batt lucky i noticed it, flying again! like if you had alarm in good while before u relocated the batt & der was no probs shudnt b dat?? maybe were the joint was made up front might not be 100% or someting loose at batt,clamps r terminal?? is defo not the cable cause u cudnt of using a better 1
  8. #18
    Feb 2011
    clare
    Quote Originally Posted by B&G Extreme Drifting View Post
    ill check all those today sure! cheers!
  9. #19
    not saying its defo jus maybe.. was there no probs with batt before relocation?
  10. #20
    cork
    did you run an earth cable from the engine bay,or ground it in the boot
