well man i had prob with my jeep few weeks ago batt kept goin dead turned out the clamp that goes on plus or minus there was two terminal screws that lock the cable tight to the clamp, they were loose & there wasnt enough jizz gettin in, i near bought new batt lucky i noticed it, flying again! like if you had alarm in good while before u relocated the batt & der was no probs shudnt b dat?? maybe were the joint was made up front might not be 100% or someting loose at batt,clamps r terminal?? is defo not the cable cause u cudnt of using a better 1![]()
