Results 1 to 10 of 15
    Member Gerry's Avatar
    Jan 2012
    the famous village of Muff
    Default airbag light help for NCT
    Car went throught NCT other day and sailed through on everything only they failed me on a visual (airbag lamp not lightin up) there is a momo steering wheel fitted so im guessin the airbag lamp was disconnected. am i gonna have to fit an s14 factory steering wheel and reconnect the lamp to get her through? if so anyone have a steering wheel layin about?
    Sounds more like the bulb is removed because the steering wheel was changed? Ive fitted timer relays working off the oil light before to get em through nct but the odd time theyd cop it still...
    Sep 2011
    Jan 2012
    Thanks lads, picked up an original steering wheel to save any messin about with fuses etc, checked down the drivers footwell and all the fuses are still in and workin so im guessin its the bulb in the dash thats been removed.
    anyone know what side the airbag bulb is? beside abs bulb or to left side? and can i get a bulb out of any nissan, almera, primera etc and stick that in?
    Cheers lads!!
    SIDEWAYS IS THE WAY FORWARD
    Member
    Jan 2012
    just stick in a 2.5 ohm resistor betwwen the points that would connect to ur airbag it will think the bag is there replace bulb and ur away!
    di Member Romo's Avatar
    Wicklow
    If theres no airbag then how can they fail ya for it not lighting up?
    There's still a passenger side airbag in an s14 so the light has to come on for that. The airbag is in the centre of the tachometer I think. If it doesn't come on at all when you start th car then the bulb has been removed
    Wicklow
    ooooooh right, cuz they failed me on that but I'll have a momo wheel on it next time so I'm presuming it wont matter
    I think they changed the rules a while back, so if you're car had an airbag leaving the factory then it must work correctly for the test. Open to correction on that though
    Jan 2012
    Quote Originally Posted by newt250 View Post
    cheers but will a bulb out of any nissan fit?
