Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Member Gerry's Avatar
    Jan 2012
    the famous village of Muff
    Quote Originally Posted by hi_im_fil View Post
    I think they changed the rules a while back, so if you're car had an airbag leaving the factory then it must work correctly for the test. Open to correction on that though
    i think you are spot on with that, as far as i can see the easiest way is to stick on the factory steerin wheel for the test and then put your aftermarket one back on after. so does anyone know if the airbag bulb out of any nissan will do the job?
    SIDEWAYS IS THE WAY FORWARD
  2. #12
    Jan 2012
    There's still a passenger side airbag in an s14 so the light has to come on for that. The airbag is in the centre of the tachometer I think. If it doesn't come on at all when you start th car then the bulb has been removed
    good man, aye the buck in the test centre said because there is a passenger airbag it has to be showin an airbag lamp.
  3. #13
    di Member Foxyfenlon's Avatar
    Dec 2011
    Wexford
    Mine failed on no airbag light, the guy in the test centre told me that if i take out the passo bag it will pass with no light
  4. #14
    di Member pinny's Avatar
    Mar 2011
    Galway
    when you pull the bulb just take one from beside it and go into the motor factors for your bulb. It'll cost a whole 20 cent . But ya any nissan of same year should be the same
  5. #15
    Jan 2012
    Quote Originally Posted by pinny View Post
    cheers, aye doin that later today, luckily i have been savin hard so i have that 20 cent scraped together. thanks for your input everyone!!
