Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 151
  1. #51
    Jan 2011
    Quote Originally Posted by hillclimber 70s View Post
    Thats very vague ,what is the fix for dash dodgers so? Out or in.
    If you already have a good bolt in cage with the front legs bent around the dash you can get two new ones made that run down the A-pillars and true the dash properly instead, cheap and easy fix to the problem!
    "Drifting is easier than it looks"
  2. #52
    Driftfest
    Oct 2011
    CORK
    Quote Originally Posted by JStone View Post
    Thanks for that ,but do you have statistics to back up that dash dodgers fail under crash conditions?.If so where are they?
  3. #53
    Jan 2011
    If you have any problems regarding the saftey regulations for prodrift you should email info@prodriftseries.com
    Thanks,
  4. #54
    Driftfest
    Oct 2011
    CORK
    Thanks,
    Sorry dont mean to be awkward but I dont understand why dash dodgers can fail,believe me I need to know asap.
  5. #55
    John do you need 2 parallel or "x" door bars if there is side impact bars in the stock doors ?
  6. #56
    Jan 2011
    They fail because in the event of the car turning over the vertical load on the a-pillar bar causes it to buckle were the bar is bent into an S shape around the dash, this usualy results in the roof being pressed down on top of the drivers head. Most Motorsport now requires an a-pillar support bar even when using a proper true dash bar,
    here's a link to the MSA regs on the issue
    http://www.racingexposure.com/blog/2...ion-amendment/
    Quote Originally Posted by Cooldrft View Post
    Yes you will need two bars even with stock doors
  7. #57
    ignition steering lock just applies to the lock yes? so i can still use the ignition and key start aslong as the lock is disabled?
  8. #58
    Jan 2011
    Quote Originally Posted by chrisb View Post
    Correct
  9. #59
    di Member keith-n's Avatar
    Apr 2011
    Bandon
    Thanks,
    Don't bother, the fuckers dont respond to emails.
    Team manfoot : Its all about the 1Fourty8
  10. #60
    Senior Member ste's Avatar
    north dublin
    Can you enlighten us on the fia approved open face helmets please John??
