No not at all... Your lock stop, or where the track rod end hits the bottom arm determines how far the rack travels. So just because the 2 hubs are different doesn't mean only one track rod end should be hitting the bottom arm.
Also no need to be gettin flowery about it, you've been told what's wrong and theres no point worrying about anything else til the hubs are right...
those hubs need to be fucked of it and new ones made up that are actually right
the issue is that when modifying hubs there is an 'ideal position' for the track rod end to bolt onto in relation to the bottom arm ball joint (in a straight line front to back)(also right to left is an issue for ackerman but lets not get into that becaues although its wrong on your hubs its not the main issue), if it is moved too close to the ball joint connection on the bottom arm then you make the distance for which the track rod has to move to achieve full lock much shorter which in turn means the rack does not need to move as far. where as what you are aiming for is that when you are on full lock your inner track rod is making contact with the rack casing and in the same instance your track rod to hub connection is at the point where it is just about to go over center and finaly the distance from the track rod end to the bottom arm is only a few mm.
with your two hubs not the same there are obviously going to be differences but when both sides are doing the same your issue is that the mounting position of the track rod end has been moved too close to the center of the hub.
hope that helps
chris
