Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: steering
    Default steering
    I'm looking to centre the rack on the 180sx as I have 1 and a half turns to the left and just over 1 turn to the right side. Can any1 tell me how to centre the rack or solve this problem
    Site Trader : Premier Performance Cars
    monaghan
    take your track rod ends off and then screw them on the same amount off turns on each side. then line her.
    www.premierperformancecars.co.uk
    Senior Member paulr5's Avatar
    Oct 2010
    Takeshi's Castle
    ^^^^ X2
    Them track rodends you have wont help the situation if its ur new bus....
    Originally Posted by sc86
    better thread would be pics of all the savage jap cars parked up hidden around the country in sheds!
    No because whores like you will buy em and break em
    Quote Originally Posted by Seamie tc View Post
    Does the rack not have to b centre to get same lock either side?
    Quote Originally Posted by paulr5 View Post
    ^^^^ X2
    No lad I got proper s14a arms for it with longer ends
    i like cake
    Dec 2009
    that'd be your hubs going full lock. not the rack by the sounds of it. worth a try of the above
    take the track rod ends off at the hub (leave them in the rack) then check the turns from full lock one way to the other, half it obviously is the center of the rack. mark this position on the steering wheel using tape, get the car lined with it on the mark then adjust your steering wheel if you want it to sit centered.
    you need to make sure you leave the track rods connected to the rack!!
    Quote Originally Posted by chrisb View Post
    Ya ill try that soon as i can cheers. At the mo I'm over a half a turn out.
    Done the above with ends off hub have 1and a half left and right. Then put the ends back on and back doin the same with the ends on. The steering arms is hitting the bottom arm on full lock on both sides. On full lock to the left when I go under car I can fit 2 fingures tyre and tension ARM and full lock right I can fit 4 fingures between tyre and left tension ARM
    i like cake
    Dec 2009
    sound like the rack is off. can you open them? see if it looks like it's been opened and try centre it yourself
    Quote Originally Posted by decobyrne106 View Post
    The rack can't b off now as i done was Chris said I centered it when it was disconnected from the hubs. Looks to me as it the modaified hubs are diff lenghts were the arm bolts on. 1 is over 3.5inches other is just over 3 that. Were the knuckle was cut and welded
