Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    MEATH
    Talking R32 gtst €2500
    ********SOLD*********
    Has 190ish km, nct till 08/12,
    interior is decent with everything working,
    R33 series 2 front seats
    aftermarket steering wheel(has bride stiched in but i'm sure it's a ebay job)
    Weighted gear knob
    Razo pedals
    jvc cd player pair 6x9 whatevers (cheapo)
    P/s air vent damaged
    Engine is stock and reads usual oil pressure readings , 1.5-2 bar at idle and 4 when driving(i'v had 3 r32's that all read about the same so i'd be happy there
    RB25 turbo with all new gaskets and rb20 actuator
    Apexi super intake
    unknown Cat-back(small blow where back box meets and centre box has dinge in it)
    Decat/downpipe
    Uprated fuel pump ( i think
    RB25 Crank pulley
    XTD 6 puk clutch/ pressure plate(good bite but can vibrate on slow engagement)
    Nismo gearbox mount
    A/C fully removed
    Purge can removed
    RB25 rad (has in and out for power steering cooler if you wanted to hook up
    just had fluids changed and new battery
    Tein coilovers(p/s rear leaking a small bit but not banging so something for the future)
    R33 lca's (modified)
    standard castor arms
    180sx rear subframe with solid bushes
    hicas removed and r33 rack/pump fitted
    drilled/grooved front disks
    good pads all round(ferodo)
    Cased s14 vlsd 4.1 ratio(very slight whine ?)
    S14 standard wheels with all good rubber
    Type M skirts and spats
    Vertex copy fibreglass front bumper
    Tints on back 3 windows
    Bad points that come to mind,
    4th gear is a wee bit notchy when your absolutely hammering- and only then can it be noticed a little
    d/s window given up, relay/motor will try fix soon
    Body is not mint, overall its pretty good. got a tap up front at some stage , only damage i can see is to the crash bar(original still there) legs / rad panel/slam panel have zero damage. Front bumper has a few cracks probably from hitting speed ramps as its pretty low.
    strip of about 12 x 2 inches of laquer peeling off roof
    some very small under surface rust on d/s front/ rear arches
    MEATH
    Thread clean bump, not in a rush to sell now so that's best cash price, can be viewed in dublin or meath
    Pm sent
    MEATH
    Quote Originally Posted by Titan Autoworks Japan View Post
    Pm sent
    Viewed today but unfortunetly couldn't agree on a price, pity the test drive was so crap, i don't miss Dublins speed ramps whatsoever, don't think Tom got out of 2nd . Changing 2 way to a welder so i can spend some more on it and keep in price
    BUMP!!!!!
    How has this not sold yet??
    Im not supposed to be purchasing since i lost my job but we'll see what happens when i sell the lexus..
    di Member danmc's Avatar
    Kildare
    will how much for the lexus
    gtst looks clean nice car for money
    MEATH
    Cheers Will , i'm only down the road from ye now if you want a look
    Away on holidays Bump - come on peeps another car might be going out of the country if someone doesn't take this, only kiddin Mike
    MEATH
    Upidy Upidy
    Moonlight Kids™ dil's Avatar
    May 2010
    Kerry
    Upidy Upidy
    spam but ...can't believe this isn't gone already, keep her I'd say!
    MEATH
    Quote Originally Posted by dil View Post
    Ah dude have the 4 door r33 to sr and a s13 i'v started to put together too , i'v done as much as i want with it so it can go, pretty sure it will go soon enough, the only viewer just couldn't agree on price but was happy with it even after me bringing it to his panel beater and even though he has a gtr in japan so it gave me enough confidence that it will sell. luckily i'm in no hurry and being away hasn't helped,
