Ya lad mask away.... You can take it off like but if your half tidy about the masking twould be perfect...
Just take ur time with it.... Once uv it based u must apply laquor within 12 hours...
Otherwise ul have to rub down again...
Also make sur uv plenty heat and put down plenty of water...
Leave on the heater for base but turn it off for laquoring...
Sum form of fan would be ideal cas once u start laquoring visibility is terrible unless the offsprays being extracted...
Oh.... and take ur time and go easy with the laquor, remember if its a little orange peely u can flat it and polish it to bring up a clear finish...
And for the base 2 light coats first, remember your building up the colous as opposed to just bateing it on..
Its ALOT easier to flat a bit of orange peal then flatting a huge run
