As above have a 180 its on tein coil overs but there is not adjustable top mounts and it is eating tires on the inside. What would I need to get to correct this? Adjustable top mounts? Toe arms,Camber arms???![]()
u will nead 2 get camber sorted and tracking sorted lad
it depends y its eating them if the toe is wrong it will eat them also if theres a camber on them it will just wear the inside but to me it sounds like a toe problem go down and get the tracking done and see what they say
even if you dont have adjusable top mounts if you lower a car enough you will get negative camber
Its not lowered that much like and doesnt look like feck all camber either. Its on 18s so cant physically lower it to much for negative camber. Ill bring it down to get tracked and see what they say sure
Any lowered s-body will have negative camber on the back and the only solution to it is to get camber and toe arms, you will need both because as soon as you fix the camber the toe will be out.
Sig removed - See rules
Try getting the car tracked and see how you get on.if it's not lowered much as you said you should have no need for adjustable arms.
ive rear adjustable camber arms for an s13 there. span new €80
same happened me on my merc and silvia, i use to just switch the tyres around when they wore
