Results 1 to 10 of 12
    Cork city
    Default Rear wheels eating tires on the inside
    As above have a 180 its on tein coil overs but there is not adjustable top mounts and it is eating tires on the inside. What would I need to get to correct this? Adjustable top mounts? Toe arms,Camber arms???
    u will nead 2 get camber sorted and tracking sorted lad
    it depends y its eating them if the toe is wrong it will eat them also if theres a camber on them it will just wear the inside but to me it sounds like a toe problem go down and get the tracking done and see what they say
    Default tyre eating
    even if you dont have adjusable top mounts if you lower a car enough you will get negative camber
    Cork city
    Its not lowered that much like and doesnt look like feck all camber either. Its on 18s so cant physically lower it to much for negative camber. Ill bring it down to get tracked and see what they say sure
    Any lowered s-body will have negative camber on the back and the only solution to it is to get camber and toe arms, you will need both because as soon as you fix the camber the toe will be out.
    Sig removed - See rules
    Try getting the car tracked and see how you get on.if it's not lowered much as you said you should have no need for adjustable arms.
    di Member damo86's Avatar
    ive rear adjustable camber arms for an s13 there. span new €80
    Cork city
    Quote Originally Posted by damo86 View Post
    Any pics???
    di Member m-sykes's Avatar
    same happened me on my merc and silvia, i use to just switch the tyres around when they wore
