My right stalk coming from the steering wheel which controls the indicators and front lights is not working.
My hazards work, and the lights flip up, but i cant turn on lights or use indicators... anyone any ideas???![]()
Yip
Using your knob to try to control lights is not a good idea. Use the switches provided
Seriously though, I dont really know but have you tried simple stuff like fuses. The inducators on the Silvia wouldnt work when the Hazard switch wasnt plugged in but thats not the case with you, i googled it and something about the relays being wonky perhaps? If the lights are popping then id imagine the (indicator) stalk is working??
havent tried fuses, (i take it they are the ones in the drivers foot well on the right)?
I push the button on the dash to flip em' up.
There was a bit of water in the connections to the bulb, would it matter much?
I wrote a reply but my bollox of a wife deleted it
Check the bulbs! And the fuses!
Went to nissan....
there are many small stupid, annoying, awkward things to be sorted to get it 100%... so i got cracking...
Was up at the nissan dealer... so of course i went to check out the parts....
Picked up this just to have...
The bolts for the seat rails were...em... lacking... so after fucking about with motor factors and stuff i went to the nissan dealer...
Trying to find the correct chasis is a bit hard, but i think he told me the corrct one in the end (check pics)...
I needed a few bolts and also needed the nuts that go onto the gearbox tunnel...
Diagram...for future refrence incase any one needs to know...
The bolts that go into the chasis...
The Nuts...
Oh! And I bought this!
Things to do...
Find seat rail for Sparco seat...
Finish removing all sound deadening..
Space out front (front right tyre is rubbing against coilover!)
Bin back two rims... (cracked spokes ---- Cracked not holding air)
Re-fix rear lights...
Buy tools!!!!!!!!!!! (money!!!!!)
http://www.halfords.com/webapp/wcs/s...egoryId_165572
pretty much all you will need for working in the garden man, jack and stands and work away
Bride or recaro rails will fit a sparco jus to let ya no man.
Best of luck with the build, its going well so far
THANKS
might make it a bit easier to get a rail now!
Ah, it sitting there not doing anything...sorting out body...
Anyone know what bettery to get?
I sent a mate into the motor factors to get one.. apparently a 200sx has one battery.. and a 180sx has two!..... dead onnnnnnnnnn!
When it comes to batteries.. can i go far wrong?
