*We're delighted to announce that TrackDay Performance (TDP.ie) have teamed up with driftireland.com to build this, the 2011 driftireland S14*
Following my first year in competition last year in the driftireland 180SX, I managed to win the Prodrift Amateur Championship, and hope to again achieve some more great results in the Non-Seeded Pro Class in this S14 in 2011. With TrackDay Performances' knowledge and expertise in building top-end race, rally and drift cars behind us, its going to be all down to me now to try drive the car to its full potential!
So without further ado, I give you an outline of some of the plans TDP and I have in mind for the car;
CHASSIS:
- A huge amount of chassis work is going to be carried out with this car, as its really important when building a competitive car that you start from the base - building the rest of the car around a fully rigid chassis incorporating a WRC spec cage which TDP will build for the S14. This rigid chassis and cage setup will allow us to run much softer suspension settings for maximum grip all round. This combined with a huge weight-loss program for the car should make it a very competitive setup!
SUSPENSION:
- After the chassis work, we will focus on the suspension. All suspension arms are going to be designed and manufactured in-house at TDP, using CNC machined aero-spec billet alluminium and high quality German(SKF) rose-joints.. Steering modifications will tie-in with a custom front and rear suspension setup that will allow for lots of steering lock in the correct way, reducing the ackerman angle as much as possible for high speed drifting!
ENGINE & ELECTRONICS:
- As TDP are a one-stop race car preparation shop, they will be taking care of all engine, drive-train and electronic issues. Using my healthy SR20DET engine from last year, it will be stripped down, machined, cleaned and rebuilt using Wossner forged pistons and the usual uprated componants. We will be running a Nistune ECU and a custom wiring loom to simplify the cars electronics and will further save weight.
Part one of the strip-down in the di HQ!
Willis giving a hand with the sound deadening
And with 4 cans of Tar and Crap remover, a perfectly clean floor
No sooner had the car arrived at TDP, out came the marker and plasma cutter
as Robbie started cutting out some of the unnecessary weight from the rear of the car.
Part two of the strip-down in the TDP HQ- the lightweight plan with the plasma cutter!!
Thats all for now folks, I shall bring more updates throughout the week!
How many non seeded and Pro's had nistune last year?
