hi
I have major problem with engine that i can not get my head around it. its a s13 sr20det 93 black top drift car. spec on car is standard ecu, injectors and airflow. boosting at .9 ~~ .car has walbro pump, fuel reg, intercooler,s15 turbo proper onestraight throw exaust .
whats happing is
start car, starts perfect,ticks over 100% no noise no rattles or bangs.
car will take rev to about 5000rpm then die out. then start perfect again try to rev higher than 5 same thing happens again.
this is what i have done to try to fix the problem
swapped ecu+
coil packs+
airflow.
fresh fuel
new fuel filtr
new plugs
tested fuel prussure
changed injectors
checked turbo piping
knock sensor
all parts i have taken from my sileighty that i know are working
im thinking that could it be actuator not opening (yet to change) and check cat.
has anyone had this problem or any suggestions what it could be.
very greatfull for any help.
thanks
niall
