Results 1 to 5 of 5
    Default Eoghan's 180sx Drift Build
    Bought this back in September and said its about time i did a thread on it. It is pretty much completely standard but will be upgrading things as time goes on and when i break s**t.
    This was it when i got it.
    Put it straight up on the lift to have a look and i was really surprised how clean it was for a car sitting in a field for a few years.
    I was delighted to find cusco coilovers are in good condition. The petrol tank had taken a few bangs tho so pulled it out cut out the boot floor and put in a fuel cell i picked up on donedeal.
    It came with a weld in cage that had been cut out of another car and half welded in and when i looked at it more i found it had more then likely been cut in and out of a few car so i cut it out once more and left it out. Then did the usual removing the sound deadening and got it ready to go for its new cage.
    Rocky was a great help alright.
    And off she goes for the new cage.
    <a href="http://www.mybannermaker.com" target="_blank"><img src="http://i.imgur.com/H9SlX.jpg" alt='Create your own banner at mybannermaker.com!' border=0 /></a><br>
    Ok so bit of an update. got the car back from smyth gates he made a nice job of it and made it seriously tight to the car, i could barely get paper in around the main hoop when i was painting it. I got stuck into the interior and think it turned out fairly nice, what ye think?
    made up a fire wall too out of some bus panels
    and plumbed up the fuel system
    The last big job left is to finish off the wiring as the car came with a half made interior custom loom,so i made up a battery box and started a switch panel for the dash
    thanks to bart for the hydro too love the cylinder mounted the opposite way to normal so it can be put in the dash make it look tidy.
    Main things left to do are:
    wiring up the loom
    plumb the hydro
    install the turbo
    prime the oil pump
    tidy up any loose ends on the engine
    get and mount an inter cooler
    and finally fire her up and hope for the best
    Jul 2012
    Nice build, really like the colour on the cage too
    Junior Member
    Jan 2015
    westmeath
    Quote Originally Posted by Ptank View Post
    Same here cage turned out well.. it set u back much in price??
    Thanks lads. It was around 700, he made a serious job of it i must put up more pictures of how tight it is to the car.
