Results 1 to 7 of 7
    A real healthy SR20 will have compression around 150-160psi.. Ive had three that were 165 PSI which is what they left the factory with.
    130psi is middle of the road.
    Probably best off to remove all the valves put new stem seals in and reseat all the valves
    Quote Originally Posted by mattybyrne2008 View Post
    Thanks Matty, Where would I get a full set of valves with seals? Nissan I suppose? Or?
    ConorF
    Thanks for the Info Stevo, would the temp of the engine make any difference regards to the compression?
    ConorF
    Quote Originally Posted by Conor sr_20 View Post
    Should be checked when engine has been up to operating temp
    Get the head overhauled & get new valve stem seals fitted aswell... cost you around €170 without cutting the valve seats. They should reface the valves to a 45* and lap them in then should be fine without cutting the seats unless it got a bad roasting.
