Results 1 to 10 of 107
    Senior Member grange's Avatar
    Or just pic up m3 running gear lol
    team ball bag
    Senior Member TorqueWorks's Avatar
    May 2011
    Quote Originally Posted by grange View Post
    Id expect them comments after page 1... not now!
    We had a 328i and a 323i both of which are now soldd on & sliding around tynagh & WGH.. having bought them pretty much to do power comarisons we have a lot more grunt in the diesel, + low running costs.. next up is getting an m3 and matching that for power..
    Btw that engine, turbo, intercooler, injectors & diesel pump are still all factory fitted.. its still untouched so a lot more power gain to be had yet
    May 2011
    Right, update
    Indirect Injection Fun
    Looking at what the guys are at in finland with the M21 engine trying to get better cylinder head flow, raising the headgasket is their way of going about it to get better cylinder head flow from their pre-combustion chambers (Swirl type chambers in the BMW's), that's lowering the compression ratio, but they're compensating by raising the boost pressure
    Bit of theory on IDI Engines:
    the idea of the pre chamber is air flows into the pre chamber in the compression stroke, the design of them in this engine causes a swirl in the pre chamber, hence the name swirl chamber is also used for this type of indirect injection chamber.. diesel is injected into the swirling air & mixes, that diesel partially ignites in the pre-chamber & creates a pressure that shoves the atomised fuel back into the main chamber. The main chamber is where it meets more air & the main combustion happens during the power stroke.
    Looking at the design of the pre chambers in this engine, I think I can achieve a higher head flow by widening the passage to the pre-chamber about 20 to 30 precent, not having to raise the headgasket atall & therefor not really much drop in the existing 22:1 compression. It should help deliver the larger quantities of diesel into the main chamber a lot faster especially under high rpm's (reving to 6000 RPM currently). If it works the engine should be a lot more rev happy, a bit noisier, and with the quantities of diesel we're injecting should burn a lot more of it & develop more power
    this could potentially cause dramatically higher combustion temperatures and higher EGT's as a result, but with water/meth injection in place that should lower the combustion temp so everything will be kept under control
    pre chamber design
    pre chamber position in the head
    taking this in mind we removed the spare engine we have for the drifter from the former dog kennel E36 we picked up a few months back. for a bit of experimental head work.
    block
    cylinder head
    6 pre-chambers removed from the head, cleaned a bit & ready to get a go on the milling machine maybe next weekend
    the entrance you see, that is going to be enlarged
    May 2011
    Quote Originally Posted by scottfreee3 View Post
    Loving this thread. I'm a massive fan of diesels and this stuff is truly fascinating. When your finished here pop over and do my car!
    I like the way you think it will ever be actually finished lol
    Anyways time for a bit of an update, Have been struggling to find time to get anything done recently with the buildup of coursework & final year project for college, as well as preparing for & attending assesments & Interviews for the Mercedes Formula1 team's Engine & powertrains division. Got through most of the hoops so far & down to final 3 in europe for 2 places with their electrical engineering team.. Would not mind working there #DreamJob
    Anyways, the update:
    Cylinder head fully stripped down & cleaned, being worked on in cleanroom conditions as you can see :P
    soaked everything in a mixture of diesel & petrol for a full week then boiled them, and finally used the die grinder to clean up the valves with steel wool... shiny
    even the shite that does build up on the intakes thanks to EGR was dissolved completely
    now down to the main job, enlarged pre-chambers on the CNC Milling machie
    jig with a face surfaced perpendicular to the angle the entrances were, the reason is that you can set up the jig repeatedly setting this surface horizontal. this ensured every chamber was cut identically and any future chambers can be cut identically too.
    after machining
    actually noticed slight variations in the casting of the chambers, these are the two that were most different... our cutting was in exactly the same position & precise across all chambers , measure the distance from the side to the casted groove in the pre-chamber and they all varied slightly, measure the distance from the side to the new machined entrance and they are identical.
    before & after comparison
    wont have time to go at this again until june
    Senior Member Eoin k's Avatar
    Fair play is all I've to say!
    May 2011
    Was home from dublin for a few hours earlier today so I attempted something I've been figuring out for a while.... How to give this lady a Remap This older ECU is before the time of the now commonplace plug in remaps, these ladies have to be stripped apart and erased with UV light before programming.. Fuck That! Picked myself up an eprom reader/writer and a few new chips...
    and this is what the ECU looks like stripped apart, notice the two chips with the stickers on them, thats actually covering the UV hole for erasing these
    chips out, read, and saved to a file then got to the hard bit, figuring out from a bunch of numbers, letters and locations how to distinguish a map from just empty space or other shite you dont need to know about and select it to make it into a 3d graph that can be looked at more visually... Headmelting to say the least, but more interesting than writing my thesis so I managed to figure some of them out
    part of the memory dump on one of these eproms... Jibberish to most :P
    then eventually you can learn to identify things and get really cool shite to show up, figure out how to convert them from hex to recognisable numbers and edit it... this is my modified torque limiter, one of the most basic maps on the ECU.. as you can see its RPM along the bottom axis, which I have increased from 4250 to 5100 and raised the injection quantity to maximum across the rev range
    This is the boost pressure map, remember the boost pressure sensor reads Absolute pressure so 2550 is actually 1.55 Bar boost pressure, this map actually lowers the fuel as the RPM's rise which is probably helping to cause our boost pressure drop
    agressively modified... Im not concerned about smoke :P also notice the maximum boost pressure has been raised and the rpms raised
    I've flicked around in a lot more of these and fixed them to give me the diesel I want at high revs... Stuck these on the new eeproms earlier and stuck the ECU back into the car and just gave it a quick try... It worked! the car doesnt rev limit anymore it just keeps reving and gives me a wee bit of smoke now without my external chip turned on..... Didnt have time to take it for a spin just yet... but it should prove to be an interesting summer getting the hang of mapping One more week until I get to go back at the other engine too
    Junior Member arronmoloney's Avatar
    Nov 2013
    Flagmount killanena co.clare
    Your a brave man to go fiddling with the internals of the ecu ...fair fucks to ya
