Results 1 to 10 of 10
    Junior Member
    Dec 2012
    I'v had two 2 euro coins with the centers taken out on each side with the last year and the rack is still good.
    Just make sure the gaiters are in good nick it all helps.
    di Member matty's Avatar
    Oct 2012
    cork laaaaaad
    Quote Originally Posted by wellyek9 View Post
    so 2 €1 coins on either side is it?
    Junior Member
    Dec 2012
    NO
    You need two, €2 coins either side.
    Mar 2013
    castlebar co mayo
    U just have to pop the center out of 4 €2 coin then just pull off your inner tie rod where it screws into the rack and use the €2 coins as a washer and slip it over the tread on the tie rod then screw it back into the steering rack again. Its defo the best €8 you will ever spend on the car
    di Member Paddy drifter's Avatar
    Oct 2010
    inistioge co kilkenny
    ive got 5mil spacers on my rack , but wouldnt it not be cheaper to get a few washers , two 2 euro coins on either side surely someone with a lathe can knock up a pair cheaper then that
    u just talk nice to me or ill tell john to make that cage out of timber and then we see who passes scrutiny
    Oct 2012
    cork laaaaaad
    On theball lads sound !! I was going to get my dad to make them in work but ill just do the €2 trick haha
    Mar 2013
    castlebar co mayo
    Quote Originally Posted by Paddy drifter View Post
    Its €8 who the hell is goin to do it cheaper than that and its alot easyer and quicker to find 4 €2 coins than it is to find someone to make them on a lathe
    Unless you have a lathe yourself
    I make them from alloy bar and 5mm as just shy of full travel then so you don't damage the rack.
    They are dearer than coins though I suppose at 10 euro a set but some people might prefer them than just using coins
    Of course, they'd be a lighter than coins too so that weight saving is surely worth a million bhp lol
    Oct 2010
    Quote Originally Posted by mike e30 View Post
    ah yeah but im a tight cunt and plus i got friends in high place :P
