Results 1 to 10 of 14
    Default paint question.wtf!!!!!
    Hi all
    Was spraying the top coat last night and this happened. Bumper was primed and keyed and cleaned before I started. What caused it?
    Thanks
    Apr 2012
    Did u use 2k primer and did that just happen as u painted it or did u stress the bumper
    its not low enough!
    The paint has reacted with the primer by the looks of it , what paint an primer are u using ?
    Halfords paint and not sure on primer it came primed
    its not low enough!
    Quote Originally Posted by jamesd View Post
    Aerosol?
    Indeed. Just want to See if I like it before the car goes for a respray
    Did you heat it??
    Primer possibly not fully cured . Happened me before
    If its fibreglass it is cracks on the fibreglass from pressure or a previous break.I think they are called spider cracks not sure how to fix the problem
    di Member AEf20c's Avatar
    Cavan
    Looks like it reacted with primer. As for spider cracks seen this stuff on Wheeler Dealers, It's Carbon Fiber filler.
