Page 43 of 48 FirstFirst ... 334142434445 ... LastLast
Results 421 to 430 of 480
  1. #421
    Quote Originally Posted by ali-d1936 View Post
    January... you can expect them to arrive around May so...
    he never said witch january
  2. #422
    I like booobies :) D-turbo-lad's Avatar
    Sep 2010
    roscommon
    Quote Originally Posted by peterhouze View Post
    thats ture i supz . if there not at my house by the 1st week in Feb il demand my deposit back not goin hang'n on for ever for them ...
    ne way pics and shizzz ..
    number on really is that i figured if i talked enough about nissans and toyota'a to my mates i may talk them into buy some and i guess payed off ha . one the lads bought this off japstuff2 on here its a fucking awsome car !!
    and then last weekend one of the lads bought this . used to be "slammedmind's " old jzx100 now converted to manual and what not never drove one before but i must say there awsome in so so many way's !!
    and some pics of the bit's and bob's ive bought for my own car the last little while ...
    oil cooler and relocator kit (needs a clean up)
    my new 18x10 ssr koeings that im waiting to arrive from japan ...
    and new alpine double din radio that i stuck in last week . just waiting on small bit for carbon wrap to arrive to do the center console ..
    still waiting on engine bits to arrive so hopefully some progress on that side next week i hope !!
  3. #423
    di Member rico180's Avatar
    Feb 2011
    Formally westmeath,currently calgary, Alberta .
    I would recommend a thermostatic sandwich plate to go along with that oil cooler kit you have...
    savage cars there bro,, there must be money still in the country!!!!
  4. #424
    di Member Dori88's Avatar
    Donegal
    I want that jzx so much but just can't make the decision t sell my own car or not for it
    Anyway - good work Gav
  5. #425
    Sep 2010
    roscommon
    Quote Originally Posted by rico180 View Post
    Yea have to get 1 next week or before it goes bk togeather !! Yea scemes to be a pound knockn bout the odd matterss yet ha. !
    Quote Originally Posted by Dori88 View Post
    Well could be sold at the right price
  6. #426
    Sep 2010
    roscommon
    so done a bit of tippin about with it in the evenings since after the start of the new year ....
    took out some of the dash/ clocks ectt .
    have no pics of it now biut got all the bulbs changed in the dash as only some were working the last while so will get some when i throw in a battery again .
    moving on from that i finished sealing off the whole of the car up in turrets ect and what i missed the last time when i hadnt the subframe down .
    will also get some pics up of that one of the evenings ..
    before i put up the subframe i checked the bushings and they were good as fucked and really they were the only bushings to be changed in the car so to speak so tipped up to shane in drive-n-style and got power flex bushings .
    aslo took out my rear coils took them all apart cleand them up again and re-set them to ride height again .
    subframe back up in place finally !!
    so got a small bit done with the engine 1 engine just few bits stuff removed to whip out the engine and box before the weekend .
    next up is to get the centers of the koeings sandblasted this week and get them all ready for painting along with the cage hopefully by the weekend . then into the fun bits .. more pics to follow ....
  7. #427
    Sep 2010
    roscommon
    well havent really updated this in a while . got some new parts for it
    brand new front ball joint
    brand new front roll bar bushings
    brand new front drop links
    japspeed shot gun rear section
    walbro 255l/h fuel pump.
    fse fuel pressure reg
    63mm rear wheel studs
    fancy titan steel wheel studs
    prob some other little bits and pieces i cant think of .
    whipped out my engine to discover the oil strainer was broke in the sum so i dug a little deeper .
    there was allready a full ACL bottom end comprising of rod big ends and thrust washers. some them are fucked so they got the bin. got a perfect crank for it so goin to be rebuild this week comming with s14 pick up pipe full cosworth bottom end and cosworth 1.1 mm head washers along with new oem front and rear crankshaft seals . just waiting to find a proper t28r as all ive looked at are all t28 non ball bearing ...
    payed for my koeings during the week so should plese fucking god il have them on monday so can get tyres on test fitted and split them to sandblast them and get the car painted .......again
    lots more to come
  8. #428
    Sep 2010
    roscommon
    Got a few bits more recently so I'll add some pics an less talking !
    Twin port elbow !
    [IMG][/IMG]
    New spigot bearing
    [IMG][/IMG]
    New front crankseal
    [IMG][/IMG]
    Rear crank seal
    [IMG][/IMG]
    [IMG][/IMG]
    Walbro/sytec 225lph fuel pump
    [IMG][/IMG]
    Fancy new steel wheelnuts and 63mm (longer) wheel studs
    [IMG][/IMG]
    Bought some other bits in the last few days
    Fuel pressure reg rail adaptor (sytec)
    Sard fuel pressure
    Elbow PIC above
    Some new exhaust gaskets
    Full set of 5defi gauges I'll have some pics the weekend
    Possibly few other bits and bobs to add soon
  9. #429
    Sep 2010
    roscommon
    EXTERIOR
    red
    full kouki kit
    Front bumper splitter and end cap
    Side skirts
    Rear bumper spats and center piece
    Kouki bumper turn signals
    Kouki spoiler
    D-Max roof spoiler
    raybrig headlights
    lazy eye thingy
    crystal side repeat's
    crystal bumper lights
    rolled arch's all round
    SUSPENSIONS BRAKE'S AND WHEELS
    Apex gen 1 coilovers
    tein front tension rods
    cusco rear toe arms
    cusco rear camber arms
    5 stud conversion
    brand new balljoints
    Full powerflex polybush kit through out
    brand new s14 inner tie rod's
    brand new s14 trackrod ends
    poly bush's in lower control arms control arms
    ploy bush steering rack bushings
    s14 4 piston front brake's
    driftworks braided lines all round
    soild steering bushing
    20mm front spacer's
    63mm rear studs with 15mm slip on spacers
    fancy stud's
    front strut brace
    rear cusco brace
    WHEELS
    SSR koeing
    Rear
    18x10 et35 ( et20 with spacer)
    225/40/18 nankang ns-v2's
    Front
    18x9.5 et 35 (et 15 with spacer)
    215/35/18 budget tyres
    INTERIOR
    apexi pencil turbo timer
    nardi 350mm 50mm concave balck red stitch
    hand brake grip
    fly off button
    60mm defi bf gauges (boost water temp oil pressure)
    japspeed short shifter
    up rated fusion speaker's
    Brand new alpine double din radio
    Black recaro speed front seats
    Blitz dual SBC
    ENGINE AND DRIVETRAIN
    black top det
    Cosworth main bearings
    Cosworth rod bearings
    Cosworth trust washers
    Cosworth 1.1mm head gasket
    New spigot bearing
    Nissan front new crankseal
    Nissan rear new crankseal
    Sytec fuel pressure reg adaptor
    Sard fuel pressure reg
    Walbro 255lph fuel pump
    braided turbo lines
    t28 s15 bb tturbo
    front mount cooler and pipes
    japspeed 4brancj plated mani
    3" elbow (dual port)
    all A/C removed including rad pump and lines
    s15 50mm alloy rad
    dw oil cap
    all multi layer gaskets
    all brass non seize nuts
    s14 vvt injector's
    light weight flywheel (1.5kg)
    exedy stage 2 3puk clutch kit
    japspeed de-cat
    blitz nur spec cat back
    3"down pipe
    2 way diff (unknow'n ) raito approx 3.9 ish
    HEL braided clutch line.
    z32 fuel filter
    diff oil castrol b373
    box oil 75w/90
  10. #430
    Sep 2010
    roscommon
    Been a while since I updated this as had really lost faith in the car..
    Put in the built engine done 79kms went fucking bang spun another bearing . bit the bullit 2 weeks later bought another blacktop non-vvt engine got it home . done a compression and leak back test and well it needed more work than expected .... So stripped it sent the head off to get new valve guides valve seats re-cut and valves re-lapped also had to go get new piston rings as well ..
    So the new. Engine specs are ....
    Blacktop non vvt
    Cosworth big end bearings
    Cosworth thrust washers
    New piston rings
    New valve guides
    Valves re-seat'd
    New spigot bearing
    New front crank seal
    New rear crank seal
    So hopefully it will be finished this week and get it in soon as run in the engine and start add'n few bits more to it !
    Also bought new japspeed rear toe arms there newly brought out in the last while by them to suit s-bodys that run super low and not catch the rear subframe un like conventional straight type arm these and bent to avoid the subframe.
    Also bought new diff brace
    Also have a new 52mm alloy rad to pick up along with alloy surround with twin fans and controller unit .more to come real soon and lots of pics as well !
