yep it is ,i think they changed to alloy after 95/96 not too sure now
2.5 is crap in the E46 as they are more grippy, heavier and engines are more restricted in most of them
2.5 or 2.8 if you get one cheap is plenty power in an E36 to start out with. Even if you cut pretty much everything bar the bare floorpan between the four wheels, a 318iS engine wouldn't be that bad with short gearing and small wheels.
thanks davem sport i have small wheels and was gonna use them as skid wheels anyways.i can get a 2.5 so she should do the job nicelythink ill need to get a few angle grinder disks so
In my opinion, if youre up for a big job like changing the engine, and haven't bought one yet,then why not to look arround for a bigger one? from my own experience and my friends, 2.8 is much better, it has more trottle response, more torque, and also it has upgraded air intake. Some of these lads are saying it will be enough, but is it ever enough?..
What ever you do, find someone thats into BMW's, and they'll tell you everything. Best of luck
soooooo ya big problem..went at wires today and now it wont start....bad idea, i cut the wires going to the door for central locking,the wires going the the airbag box in the back,wires going to the sunroof and wires for speakers and lights inside the car. anything there i shouldnt have cut?![]()
If you definitely only cut these, than it shouldn't affect car starting.. Recheck and make sure you didn't cut any sensors. And also check fuses.. If you were working at the back of car, maybe u disconnected fuel pump by accident. See if it pumps the fuel when ignition on..
Its annoying when something like that happens, I know the feeling![]()
ok so i didnt disconnect any wires going to the fuel pump...the car isnt even trying to turn over it just makes a click noise when i turn the key and its not because the battery is dead![]()
