Results 1 to 10 of 19
    di Member WayneR33's Avatar
    Jan 2012
    Kildare
    Yep just make sure you tell them it has a welded diff and your grand
    Quote Originally Posted by WayneR33 View Post
    No dont tell them its a welded diff..............
    Make sure to tell them its a aftermarket limited slip diff and it is not to be tested on the rollers as per nct specs
    Member cruising4pussy's Avatar
    Jun 2012
    dublin
    k so best to tell them yeah
    Mar 2011
    kk
    i passed with a welded but i jus told them it was a 2 way cos they failed one of the lads with a welded diff so jus tell them its a 2 way
    Jun 2012
    dublin
    sound lad
    di Member barman's Avatar
    Mar 2011
    kilkenny
    did the car pass after ?
    di Member andy t's Avatar
    i passed with a 2way ,,, told told them there was an lsd in the car
    Team Twenty !
    SR20 in the front 2way in the back!
    Will the rollers fuck up the 2 way or something??
    not just 2 ways, can damage any lsds.
    May 2011
    Another reason is if you've a welded diff or 2way and you get a brake test on the rollers with just say no l/h brake, a welder will give the impression of a brake even tho there's none, but the tester should notice it when movin the car!
