How's it goin?? I bought myself a daily 318i nt an is just wondering Wat the best way to get her sliding is as in Wat to do to the diff other dan weld it?? Thanks in advance!!
only other option is get an lsd, but theyre 250ish for one. just weld it.
if you do want to get an lsd you have to get a small case one, lsd from an m3 wont work.
and then pray for rain
Follow us on Facebook, CLICK the picture and LIKE please.
<a href="https://www.facebook.com/pages/Team-Nocturnal/245958445511099?ref=tn_tnmn"><img src="http://i49.tinypic.com/bhktvp.jpg"></a>
Thanks lads!! Wud weldin it b dodgey on the road?
i had a few welded & are the finest once you get used to em
another thing with a bmw is to use smaller rear wheels as they tent to bust halfshafts with bigger wheels.......ive 2 15" bmw alloys there with good tyres if you wanted ,40e,
Team Twenty !
SR20 in the front 2way in the back!
you could get it shimmed if you didnt want to weld it
Iv driven with a welded diff in my yoke 4 ages and Iv never blown a halfshaft and der was 18s under it, I blew the diff alrite tho haha,
The only thing I didn't like about the welded diff tho was trying to park the car other than that it was grand
x2.only problem i find is parking really.blown 1 half shaft so far but for abit of cheap fun there good aul laugh.15s on the back.loads of psi and pray ta gawd it rains!!!! i heard a diff out of a 316 is slightly better ratio? not sure how true that is tho tbh! iv a 316 diff in my 320 and it can slide no problem atall to the limiter in 2nd gear and even manage 3nd a small bit but thats pushing my luck abit! (in the rain obivously)![]()
as was said only bad thing about them is parking, but you get used to it. once you go above 20mph its like driving any other car.
316 diffs are actually a longer ratio than 320 diffs, not by much now 316 is 3.38 and 320 is 3.45. youd need an 316 auto diff to see any improvement.
i put a decated 325 exhaust onto my 320 and it made a serious difference, can skid in the dry now, also have a lightweight flywheel in it though which was also a big improvement.
Il get it welded so!! Thanks lads![]()
