Only problem with viscous fans are they take alot of rev out of an engine as its a pretty big fan to be lagging a pulley!
But other than that they are 100% for cooling.!
And oem coolant sensor switch is what your after.
Its simple and easy to get it running like this.
as for taping into the ecu, not fully sure how the ecu sends a signal for the fans to turn on , on a sr20 but if its ordinary 12v or an earth signal off it you'll have no problem doing that to a relay!
