Hey Lads. After blowing my turbo Greddy t517z turbo at the last Tynagh Driftfest, Chucky and I need to get our asses in gear and replace it, now i have sorted another new turbo (same as above) to go in, but I need to know what caused mine to go the last time so it doesnt happen again.
The last turbo, didnt blow any smoke, it just stopped boosting (none at all)
There is massive shaft play. So I need the boffins to advise me on what to check that could have caused the issue in the first place.
Oil feed and return lines, Water lines etc. But how do I check them? Do I run the car, pull off an oil line on idle and watch oil come out????? (Could be the stupidist comment seen on here for a while!)
How would i check to see if its getting water, or if the return lines are clear?
Any info would be appreciated.
Cheers
Magoo
