Results 1 to 10 of 19
    di Member srbrian's Avatar
    Kerry
    That's what I got today, co is double from what it was the last time.
    Lambda was reading .98 so surely lambda sensor is fine?
    Thanks
    Quote Originally Posted by srbrian View Post
    Thanks
    leak in ur exhaust. only has a car pass through the garage last week with similar reading leak after oxygen sensor
    cork
    maybe its a gasket issue since you put in the new cat?
    Member
    Nov 2011
    if it was a leaky exhaust you would prob have a lean lambda reading aswel
    Kerry
    Thanks for the advice lads. I Just went through the exhaust system and i found a blow after the cat joint and another where the rear hanger for the exhaust somehow separated from the system so i'm going to get them welded up.
    Could the lambda sensor cause that aswel? Eventhough the lambda reading is .98 within the range?
    Member
    Nov 2011
    it could cause it because the co is partialy burnt fuel so a high co reading would indicate a rich mixture to me but ive had this problem before and changed the lambda sensor and air filter and gave it a good hard drive before the nct to get the cat hot and it passed
    di Member pepsterx's Avatar
    Mayo
    Quote Originally Posted by bluebzr View Post
    No you would not!!! Small leak will only show on high idle and lambda reading will be fine !!
    di Member hoopsbhoy's Avatar
    Sep 2010
    Quote Originally Posted by pepsterx View Post
    My lambda was off, nothing else out in test. And it was a leak.
    Member
    Nov 2011
    if there was a leak after the lambda sensor you would get a lean lambda reading
    Kerry
    agreed i should have mentioned where on the exhaust i was talking about
    Your contradicting yourself, if you had a leak after the lambda sensor would that cause it to get rich CO readings?
