Results 1 to 10 of 15
    Aug 2010
    Default Sr20 help needed
    I've fitted an sr20 engine to my car engine was starting first time and running ok on till last weekend I was fitting a boost and temp gauge every thing connect up as it should be I then put the battery back in and tryed to start the car but the car did not start all I got was a click of something and a spark of the earth strap on the battery tryed to start it a few more times then it blew the 100amp fuseable link in the fuse box has anyone got any idea on what the problem mite be any help would be greatly appreciated
    cork
    is it turning over
    di Member pinny's Avatar
    Mar 2011
    the problem is more than likely your wiring or you connected the battery the wrong way ?!
    the shit has hit the fan if you blew a 100 amp fuse
    do a continuity test on all your fuses and go from there
    Feb 2011
    cork
    you have a live earthing off the body lad probally got the wires mixed up on your gauges ,where did you take the power from for the gauges? pinny lol (the shit has hit the fan if you blew the 100amp fuse) but its true.....hope your ecu is still ok
    Aug 2010
    I've connect the gauges to the key as I have done before on other cars and they worked fine how will I no if the ecu is gone someone has said to me It mite be some relays if this is the case witch ones
    Mar 2011
    Quote Originally Posted by 20vees View Post
    Even bits of the fuse may have hit the fan with a bang like that lol
    Aug 2010
    Quote Originally Posted by mr.jailbait View Post
    is it turning over
    Not turning its was just clicking before the fuse blew haven tryed it since I'm waiting on fuses
    cork
    check the wires on the starter and alternator
    Aug 2010
    I checked them there all fine
    cork
    ecu could well be fucked
