Results 1 to 9 of 9
    Member
    Feb 2012
    dublin
    Default 180 dash cluster lights gone?
    driving home last night in the 180 when the dash clock lights just went, all the gauges still working just no bulbs lighting, cant understand japanese so went through all fuses and in drivers footwell found a blown 10amp fuse, put a new one in and blew straight away, any ideas? shorted somewhere or would the clocks be dodgy?
    if u aint first...your last. SHAKE N BAKE!
    Check and see has your wheel cut through the wires in the arch
    Member
    Feb 2012
    dublin
    as in wheel archs like? checked there all looks good, all liners still intact so cant have cut wires
    MEATH
    Quote Originally Posted by antokwon View Post
    Pull off the liners and look behind them at the loom
    its not low enough!
    youll have no parkers or back lights either, short could be anywhere around the back too, or could be the ilumination wire for the radio, left loose if it earths itll blow the fuse!
    Member
    Feb 2012
    dublin
    radio still illuminating tho would that not go too if it was that wire? nothin worse than wiring problems ha, had an alarm fitted last week i wonder would it have anything to do with it?
    di Member Deco84's Avatar
    Dublin North/West
    Ya must have mice lad common problem with the oul Datsuns
    We can't stop here this is bat country
    Member
    Feb 2012
    dublin
    jesus dont say that man, had a corsa in the job the other day with abs light on, noticed all the wires chewed under the scuttle panel, took it off and called d lads over to have a look n a mouse ran straight from the heater duct up one of the lads arm and out the workshop, screamed like schoolgirls hahaha
    Dublin North/West
    Ha ha best off settin a trap
