Quote Originally Posted by driftescort View Post
Lovely! Any experience of the TPS sensor causing a miss/hesitation? I had this today and the only way to fix it was unplug the TPS sensor? Suppose I should replace it?
Yep a dirty track on the TPS can cause extra pump effect fueling. Try replacing it. You will need a consult cable to correctly set it.
Robbie
