Results 1 to 7 of 7
    Default Sr20 gearbox part... ASAP
    Well lads,
    Getting the clutch done on my s14 today and it was discovered that the sleeve the release bearing sits over has broken..... the sleeve is attached to the gearbox with i think is 5 or so bolts and I need this part before we can re-fit the clutch....anyone have a mangled sr box i can buy that part out of?? ASAP!! in the dublin,wicklow,kildare, meath or louth area please text me on 0863334495 as I might not be online, i can collect 2m or monday!! its the bit that bolts off that ive circled that we need!
    cheers
    Steve
    anyone wanna swap s15 helical lsd for 1.5 or 2 way...
    di Member bart's Avatar
    laois
    Quote Originally Posted by stevek View Post
    Well lads,
    cheers
    Steve
    I'm doing a box for one the lads Monday evening. Can get it for you then
    is it repairable? i can weld cast alloy no bother.
    have him sorted lads
    Does this happen often? Same happened my box a few months back!
    Quote Originally Posted by hi_im_fil View Post
    have seen 2-3 like that
    got sorted today lads, cheers ciaran!
