Results 1 to 10 of 11
Thread: Weird Ticking
    di Member Daraghs14a's Avatar
    Ennis
    Default Weird Ticking
    Have a funny ticking noise coming from the engine as soon as you touch the throttle also as I was moving the gear level the same tick was there seem to be in the area of injector or coil pack . Any ideas,, Also should there be a earth on the gearbox ?
    di Member Deco84's Avatar
    Dublin North/West
    It could be ur speedo sensor on the box
    We can't stop here this is bat country
    Senior Member grange's Avatar
    is it when you start it up? or is it all the time. cause mine and my mates s15s make a tickn noise for a secs after engine had bein turnd on and just as im moving of in first
    team ball bag
    May 2011
    Quote Originally Posted by grange View Post
    Wat ur talkin bout is vvt rattle, prob in need of changing ur vvt sprocket!
    Ennis
    No there is no rattle when it starts. it's as soon as I touch the pedal it does it but it doesn't do it every time .
    Site Trader: TDP - Trackday Performance
    Quote Originally Posted by Daraghs14a View Post
    Id it a VVT engine? If so it could be the start of a VVT hub problem or low oil pressure to the VVT hub just off idle.
    Robbie
    May 2011
    Does sound like vvt rattle thats if it is vvt engine!
    Ennis
    ya it is a vvt engine . but I was told the vvt was taken out already and normal s13 gear put in . But how would moving the gear level create the same effect
    cork
    im sure vvt only engages when you put it into gear
    in neutral its bypassed
    If your TPS is not set rite by moving your gear lever you could click off the neutral switch engaging the VVT pulley...They can rattle for a split second as they engage sometimes...
    If this is the case retard your TPS slightly till its only clicking with car in gear and throttle on...
    10.5sec 1/4 mile @140mph Fastest s14 in Europe down 1/4 mile...
