mine are very similar figures on my ca18det using castrol/liqui molly 10w60 with very similar setup, just im using small subaru wrx oil filter instead of large nissan one, and my tubby is a garrett t28BB![]()
Oil pressure will always be high when cold. As long as it comes down to a normal level when on warm idle its noting to worry about. On acceleration the oil pressure will increase.
its still a bit high at normal running temp but its been like that for a long time i first noticed it bout 3 - 4 years ago when the guages were fitted they were cheapo gauges nd i tought it was the oil pressure guage that was wrong but it was mapped a couple of times like that and its done loads of events and track days like that it was just curiosity that had me check it
Are the pressures at higher revs while driving or in-situ? it is a bit high but not hugely. thats from my experience but maybe someone with more knowledge could clarify a bit further.
be interesting to put standard filter in oem position do away with the relocation kit and test again i will check shed think i have standard filter there somewhere
