Little update,,
Picked this up
I have since changed my engine plans, it no longer will be getting an RB:-( I picked up a 1JZ engine for very very small money and it is working out much more cost effective and means I will get the car finished alot sooner, will just be giving the engine a freshen up, set of race bearings, rings, hone the block and surface it, CnC the chambers in the head, surface it and a little bit of porting, and a new steel head gasket,, should be good for close on 600hp then!!
I also bought a Nissan 350z 6speed gearbox, this will be getting mated to the JZ,, savage box with really good ratio's,
And I bought an OMEX 710 ecu which will be getting updated to the very latest software with anti lag and all the other fancy stuff. I did plan on putting in a MoTeC M84 but again the cost of the OMEX will help me get there that bit quicker,,
I will have the engine built within the next 3 weeks and then it's up to work (TDP) with me to get the machining done on the gearbox to make it fit,
So all going well my plan is to have the engine and gearbox finished fitted in the car ready for wiring within two months!!
