you might have bent the rack?
your rack is hardly off centre? or was it all done with the alignment?
did you change the tyre after clipping the kurb? if so are you sure its the same size as the opposite tyre on the other side,also check your top mount nuts and studs arnt loose,if not jack up the car and grab either side of the wheel and shake to see if it moves side to side top and bottom to check the bearing could be gone after a bang like that, hope this helps
